TwinTurbo.NET: Nissan 300ZX forum - Tuner Pro is great Program..
Subject Tuner Pro is great Program..
Posted by Cjw3 on June 21, 2016 at 9:29 AM
  This message has been viewed 321 times.
In Reply To TunerPro will read the ROM dump posted by jerdobi on June 20, 2016 at 11:27 PM
Message And it's fun to looks at all the Bits and Flags..
HOWEVER.. you have a STOCK set of Injectors on your car.. the only way the ROM K Value would cause you to run rich, is it you have K values for SMALLER than Stock Injectors.. IE NA K values..
ANYTHING is possible, however not likely..
Your Car also will Idle with O2 Cycling ( One bank Only ) and if your K values were out of the Ball park, that would not happen..
Your Fuel Correction Percentages are 103/107 which says the ECU is having to ADD about 5% fuel to get the O2 Mixture proper..
I think your K value is Proper
Cj
