TwinTurbo.NET: Nissan 300ZX forum - The only free software I've been able to work with is...
Subject The only free software I've been able to work with is...
Posted by -Grimm- on June 20, 2016 at 7:24 PM
  This message has been viewed 305 times.
In Reply To Re: Trick to connecting to ECU?? posted by rightfoot on June 20, 2016 at 12:12 PM
Message Emance Consult. And it isn't too shabby for a free program.
Try and find the download, if not I still have the installed I can send you. It worked perfect on my OEM ECU, my JWT ECU fought it a little bit but I found a way to get it to connect;
Connect to the ECU (you can auto scan for the port on your computer)
If you just wait for it to read the sensors it will error out, so I quickly click 'Active Test' on the toolbar and turn on any relay (doesn't matter what, as long as it sends a command)
The sensors will start snowing data instead of 'N/A'
If you can't auto scan in to your ECU you either have a wiring issue or don't have all the proper drivers installed. May also have to run in comparability mode, I don't recall
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2008 Honda Civic (DD)
2014 Nissan Murano (DD)
1969 Chevy C10 (Toy)
1969 Chevelle (Toy)
