TwinTurbo.NET: Nissan 300ZX forum - Injectors installed and the ECU K-value
Subject Injectors installed and the ECU K-value
Posted by jerdobi on June 19, 2016 at 11:04 PM
  This message has been viewed 338 times.
In Reply To rich idle, will soon remove/install injectors w/new o-rings posted by surfer31337 on June 17, 2016 at 08:32 PM
Message Do you have the injectors flow sheet and what is the flow rate for them? That said, I assume you have a custom ECU chip, so what's the K-value? The ones you buy are going to tend to be rich or maybe you go the wrong one. I'd check it.
