TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Low Octane Flag in Conzult
Subject Re: Re: Low Octane Flag in Conzult
Posted by Metacom on June 15, 2016 at 9:25 PM
  This message has been viewed 231 times.
In Reply To Re: Low Octane Flag in Conzult posted by zromtech on June 15, 2016 at 11:36 AM
Message Hmm, my compression numbers are higher than spec at 200-210 across all 6. Ive been tracking a rough idle, and using conzult dialing the idle RPM to 900 the ecu sets ignition timing at 0 deg BTDC and that's the only way to have a reasonably smooth idle.
But with the TPS unplugged the idle is smooth in any range of idle RPM and the ECU locks the ignition timing at 10 deg BTDC as it should with a 96.
So I dont think I am having excessive knock...
