TwinTurbo.NET: Nissan 300ZX forum - Install isn't too bad. Hardest issue is access to the
Subject Install isn't too bad. Hardest issue is access to the
Posted by jzack on June 14, 2016 at 11:53 PM
  This message has been viewed 225 times.
In Reply To Fuel Pump Regulator Replacement/Install posted by jpwiega on June 14, 2016 at 06:10 PM
Message bottom clamp for tightening. I installed a few washers as spacers so it sits up a little higher after being bolted down. Gives a little more room to access the clamp (since you'll need to check again after a few days since a new hose compresses). Just relieve fuel pressure and plan to cut the old hoses for easier removal. Use some petro jelly on the hose barbs to make new hose installation easier.
Can't comment about the autozone part, I used Nissan OEM last time I replaced.
