TwinTurbo.NET: Nissan 300ZX forum - i feel so stupid
Subject i feel so stupid
Posted by wh0sjeff on June 12, 2016 at 9:43 PM
  This message has been viewed 290 times.
In Reply To Re: Re: rear main seal issues posted by wh0sjeff on June 11, 2016 at 04:12 AM
Message so my massive rear main seal problem turned out to be the oil feel line for the drivers turbo had been compromised right at the banjo bolt where it bolts to the block anf oil was running all the way down the side o the block to where the rear seal is and dripping to the ground. go figure! well it was also dropping off right over the sub frame. I just thought that was something else I had to address. I replaced the line and wa-la, no more leaks. by the way does anyone know that restrictor size is correct for journal bearing turbos? I have ss lines and I know the oem lines had the restrictors inside them
1
