TwinTurbo.NET: Nissan 300ZX forum - It shouldn't immediately lose a ton pressure. Should
Subject It shouldn't immediately lose a ton pressure. Should
Posted by Tanley (ATL) on June 11, 2016 at 7:43 PM
  This message has been viewed 320 times.
In Reply To Boost Leak test posted by coujo on June 11, 2016 at 06:25 PM
Message slowly drop, unless you have a large leak. Trick is to maintain 5 lbs using a compressor and regulator while listening for leaks and using Windex or soap/water to pinpoint the smaller leaks you might not be able to hear.
