TwinTurbo.NET: Nissan 300ZX forum - Re: one cylinder not firing coil and injector ohm okay
Subject Re: one cylinder not firing coil and injector ohm okay
Posted by ttz'in (norcal) on June 11, 2016 at 3:33 PM
  This message has been viewed 458 times.
In Reply To one cylinder not firing coil and injector ohm okay posted by Fly-Surf on June 11, 2016 at 01:56 PM
Message If coil pack checks out per Grimm, might try a (temp.) jumper wire from #1 injector ground wire to #2 injector ground wire and see if #1 injector gets trigger signal.
If idle is smooth problem may be IC circuit driver in ECU.
Contact Gary, aka DVDBURN for repairs.
