TwinTurbo.NET: Nissan 300ZX forum - Not with a multimeter
Subject Not with a multimeter
Posted by -Grimm- on June 11, 2016 at 2:43 PM
  This message has been viewed 371 times.
In Reply To one cylinder not firing coil and injector ohm okay posted by Fly-Surf on June 11, 2016 at 01:56 PM
Message But you can test the coil pack by grounding a spare spark plug on the car while it's running and see if it is sparking (don't shock yourself)
For injector signal, you need a noid light or similar for an easy check.
I soldered some resistors to LEDs and used those as noid lights for all 6 cylinders when I was setting up my ECU and new coil packs. ~470 ohm resistor will give you 25 mA and light up most small over the counter small LEDs
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2008 Honda Civic (DD)
2014 Nissan Murano (DD)
1969 Chevy C10 (Toy)
1969 Chevelle (Toy)
