TwinTurbo.NET: Nissan 300ZX forum - Ok, the reason I ask is because I checked it when I
YlwPrlZTT
on June 09, 2016 at 4:44 PM
You can check for play on the exhaust side.
posted by white22sky
on June 09, 2016 at 04:34 PM
installed my downpipes and there was no play. I just wanted to know if that is an indication at least of some sorts. Thanks!
Checking turbo shaft play through exhaust turbine?
YlwPrlZTT
15:39:57 06/09/16
white22sky
16:34:11 06/09/16
Ok, the reason I ask is because I checked it when I -
YlwPrlZTT
16:44:54 06/09/16
You should be okay then. (n/m)
white22sky
17:01:57 06/09/16
Axial play can be measured on either end
-Grimm-
16:49:31 06/09/16
In that case I guess my stock turbos are doing pretty good.
YlwPrlZTT
18:38:13 06/09/16
For reference here's what it looks like when it's bad
OverZealous (CT)
22:16:38 06/10/16
