TwinTurbo.NET: Nissan 300ZX forum - Sounds like a ground issue but...
Subject Sounds like a ground issue but...
Posted by DVDBURN (MD) on June 02, 2016 at 12:42 AM
  This message has been viewed 382 times.
In Reply To Re: Does the engine turn over when you crank it... posted by AaronR on May 30, 2016 at 08:16 PM
Message The small wire that connects to the battery terminal is known to break right behind the connector. If that wire isn't connected everything will be dead. I would check the wire's connection by removing it from the battery, checking its continuity to the small fuse box in front of the battery and reconnecting it to the battery. Otherwise, make sure the battery post are clean and start checking all the grounds.
www.mytwinturbo.com
Nissan Data Voice on YouTube
