TwinTurbo.NET: Nissan 300ZX forum - after an engine has sat for a while, would you....
Subject after an engine has sat for a while, would you....
Posted by genic on May 30, 2016 at 10:26 PM
  This message has been viewed 383 times.
Message do the following before firing it up? (please add anything that i might have missed)
1) drain ALL fluids
2) flush the coolant system
3) replace the coolant with distilled water & antifreeze (30/70? 40/60? 50/50? mixture of water/antifreeze)
4) flush the oil system with new synthetic 10w/30
5) replace the oil in the system with new synthetic (which kind, which weight??? need suggestions on this one)
6) crank by hand (or drill) in 20 second spurts for a total of 2-3 minutes with the fuel pump disconnected (via fuse relay)
7) ????
8) put everything together for a running engin and try to crank it??
9) profit!!??!?!?!!!
fyi, i have put an larger oil cooler via a sandwich adapter on the oil tree with filter.
of course the gas will be drained and replaced with new gas
so, what have i missed that YOU would add or do differently??
