TwinTurbo.NET: Nissan 300ZX forum - Re: Is the smaller 12v wire @ the battery terminal broken off?
AaronR
on May 29, 2016 at 3:38 PM
posted by Bernie (NoVA)
on May 29, 2016 at 10:54 AM
Its a little loose in the terminal lug, but I'm still getting power at the fusible links.
No accessory power and doesn't start
AaronR
18:55:37 05/27/16
What's the battery terminal voltage? (n/m)
jzack
19:23:13 05/27/16
Re: What's the battery terminal voltage?
AaronR
19:34:49 05/27/16
With the car off it should only be about 11.6 or so.
jzack
07:46:20 05/28/16
Re: No accessory power and doesn't start
Stokens (AR)
20:56:12 05/27/16
Oh wait...
Stokens (AR)
21:02:15 05/27/16
Starter relay under the cover in the driver side wheel well.
DVDBURN (MD)
18:10:47 05/28/16
Re: Starter relay under the cover in the driver side wheel well.
AaronR
00:28:46 05/29/16
10:54:19 05/29/16
Re: Is the smaller 12v wire @ the battery terminal broken off? -
AaronR
15:38:52 05/29/16
Bypass starter relay and test, also suspect ignition switch. (n/m)
16:46:36 05/29/16
Have you removed each fusible link and inspected closely?
YlwPrlZTT
19:58:08 05/29/16
Re: Have you removed each fusible link and inspected closely?
AaronR
20:14:57 05/30/16
Does the engine turn over when you crank it...
DVDBURN (MD)
20:23:45 05/29/16
Re: Does the engine turn over when you crank it...
AaronR
20:16:30 05/30/16
Sounds like a ground issue but...
DVDBURN (MD)
00:42:23 06/02/16
do you get ANY power inside whatsoever? Dome lights? If not
YlwPrlZTT
09:22:09 05/31/16
Check your battery positive cable all the way down.
pandamanz32
08:58:12 06/02/16
