TwinTurbo.NET: Nissan 300ZX forum - Code 21 Issues
Subject Code 21 Issues
Posted by FlawleZ (San Antonio) on May 22, 2016 at 12:06 AM
  This message has been viewed 336 times.
Message Recently picked up a '93 Vert that previous owner couldn't get running. I've started to tear trace down the problem and here's where I'm at so far:
Code 21 from ECU.
I've replaced CAS with new unit, no dice.
CAS plug at harness does NOT have power.
Of course no spark and no fuel due to no CAS signal to ECU.
Previous owner stated he tried replacing ECU to no avail. I feel like there's a bad ground or no ground situation. Fusible links tested good. Relay box has power up to ignition relay. Does the 12v signal to CAS come straight from the ECU?
Also, I found this mess when I went to pull code. Any idea where these are suppose to go? They appear to be grounds but not sure.
Thanks in advance!
545 RWHP & 540 RWTQ
On The Dyno
"Ahh, to have the pos 323 appreciated by a 30k evo
owner."
-SactoTodd
