TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Typically when this happens it's due to bad wiring of
ttz'in (norcal)
on May 18, 2016 at 11:19 PM
posted by Mglide86
on May 18, 2016 at 08:31 PM
Had similar issue with Clifford aftermarket alarm as well.
Fried TCU will do it.
May also take out the diode taped to the support bar under the trim panel behind driver seat.
Access diode by removing trim panel that covers headlight aiming tools.
Dash lights and pod lights not working
Mglide86
21:54:55 05/17/16
Do your low beam headlamps work? (n/m)
jzack
22:14:17 05/17/16
Re: Dash lights and pod lights not working
Mglide86
23:11:35 05/17/16
jzack
18:05:43 05/18/16
Mglide86
20:31:22 05/18/16
Re: Re: Typically when this happens it's due to bad wiring of -
ttz'in (norcal)
23:19:15 05/18/16
Did you turn your dimmer all the way up?
DVDBURN (MD)
20:12:59 05/18/16
