TwinTurbo.NET: Nissan 300ZX forum - Do the timing belt, water pump, thermostat, all hoses>>
Subject Do the timing belt, water pump, thermostat, all hoses>>
Posted by ZUL8TR on May 16, 2016 at 1:18 PM
  This message has been viewed 494 times.
In Reply To Water pump /timing belt posted by Rayvon on May 15, 2016 at 05:34 PM
Message all accessory belts, tensioner, idler pulleys and bolts, as for the crank and 4 cam seals your car is 26 years old and they should be done. But if you are not experienced with pulling the old seals without damage to the seal riding surface you could make things worse than leaving them alone. Do you have access to someone with experience on this? When you pull the timing belt covers off if the crank and/or cam seals show signs of leaking oil you have no choice but to replace them all even if just 1 of the 5 are leaking.
ZUL8TR in Orlando,FL
