TwinTurbo.NET: Nissan 300ZX forum - Re: Fixed and Follow Up Post: Mystery Sounds
Subject Re: Fixed and Follow Up Post: Mystery Sounds
Posted by OverZealous (CT) on May 12, 2016 at 7:47 PM
  This message has been viewed 409 times.
In Reply To Fixed and Follow Up Post: Mystery Sounds posted by Stokens (AR) on May 11, 2016 at 10:09 PM
Message Congrats!!
This may not be timely but figured since I looked through your past posts I'd add this...
>> I didn't get the rear main seal done properly last time, so it's leaking . Does the Z have a low oil pressure warning light?
I doubt you put the main seal back improperly. If you've got a grove on the crankshaft aligned with a new seal it will leak again. I fixed it with a SKF Speedi-Sleeve from NAPA.
No, there is no low oil pressure warning light. In fact the slow responsiveness of the oil pressure system makes it very insidious to say nothing of the poor reliability of the stock oil pressure sender. I recommend the Kkroft FIX.
OverZealous (CT)
My General posts (click)
