TwinTurbo.NET: Nissan 300ZX forum - BTW - if the upper plenum wasn't ever pulled I'd suggest
Subject BTW - if the upper plenum wasn't ever pulled I'd suggest
Posted by jzack on May 10, 2016 at 5:00 PM
  This message has been viewed 501 times.
In Reply To thank you for thoughtful response, here is some more info... posted by surfer31337 on May 10, 2016 at 01:28 PM
Message doing that to replace the o-rings. There's other stuff that needs attention such as the under plenum coolant lines or a deletion as well as the hidden fuel rail end hose replace.
Having done the Dremel method for a single injector before pulling the plenum to do all of them -- DM is a bit of a pain not to mention all the metal shavings it generates.
Just my 2 cents...
