TwinTurbo.NET: Nissan 300ZX forum - thank you for thoughtful response, here is some more info...
Subject thank you for thoughtful response, here is some more info...
Posted by surfer31337 on May 10, 2016 at 1:28 PM
  This message has been viewed 389 times.
In Reply To You need to narrow down your problem first. posted by bartz32tt on May 10, 2016 at 01:16 PM
Message I've replaced spark plugs, no boost/vacuum leak, set the ignition timing, replaced both O2 sensors, no ECU codes.
as I mentioned, the engine is very smooth and powerful, engine runs very good, smooth and fuel mixture is appropriate, above 2000 rpm, steady boost at 14 psi.
I will do the power balance test, as you suggest, and test the injectors resistance, and the fuel pressure, to rule those out, thank you
