TwinTurbo.NET: Nissan 300ZX forum - Power steering leak
Subject Power steering leak
Posted by L£AÐZX on May 05, 2016 at 8:13 AM
  This message has been viewed 536 times.
Message I have a bad leak coming from the metal elbow where it meets the pump. Is there supposed to be a gasket or rtv at that connection? I just took it off and cleaned both surfaces then used a makeshift gasket only for it to leak worse. Took it apart again, cleaned once more then tightened it up without a gasket but it still leaks... Its just a constant steady drip until the resivoir empties. The pump was a z1 rebuild and the elbow is oem.
