TwinTurbo.NET: Nissan 300ZX forum - Have batt checked as well as alt output with a checker >>
Subject Have batt checked as well as alt output with a checker >>
Posted by ZUL8TR on April 29, 2016 at 4:04 AM
  This message has been viewed 285 times.
In Reply To Electrical issue posted by YlwPrlZTT on April 28, 2016 at 07:26 PM
Message that put the entire system through the paces. Check your ground connections there are a few. When you cleaned the + and - batt posts did you get both the cable clamp and posts shiny bright and put dielectric grease on the surfaces before installing the cables? You may also have a voltage draw somewhere when the engine is shut down or excessive draw when the engine is on?
ZUL8TR in Orlando,FL
