TwinTurbo.NET: Nissan 300ZX forum - I forget the specifics
Subject I forget the specifics
Posted by Goldchocobo on April 28, 2016 at 9:21 PM
  This message has been viewed 486 times.
In Reply To Tips on how to repair the shielded wiring on the Det sensor? posted by doug8867 on April 28, 2016 at 12:04 PM
Message But I would just wrap the shielding wire around your hot wire, and make damned sure it isn't grounding out on anything as you'll have a ground loop. I had this exact problem last year with a tiny sliver of shielding wire grounding out on the plenum, causing intermittent code 34's.
The shielding wire doesn't connect to anything. Just wrap it around the hot wire, and electrical tape/heat shrink it up.
