TwinTurbo.NET: Nissan 300ZX forum - I did nothing special just replaced the OEM Connector with a
Subject I did nothing special just replaced the OEM Connector with a
Posted by jzack on April 28, 2016 at 2:23 PM
  This message has been viewed 471 times.
In Reply To Tips on how to repair the shielded wiring on the Det sensor? posted by doug8867 on April 28, 2016 at 12:04 PM
Message Set of male/female (sealing) crimp on connectors. Put some tape and then heat shrink tubing over the crimp ends where the wire enters the connectors to make sure that side is well sealed too.
Never had any issues either. As I recall the actual sensor has no grounding point, the shield just runs to the sensor but doesn't actually ground to the engine block there.
