TwinTurbo.NET: Nissan 300ZX forum - the block/head match is not the problem
shaggee
on April 28, 2016 at 8:52 AM
91 tt head mating with 95 na short block
posted by Oriznal
on April 27, 2016 at 10:05 PM
Its the later lower intake that does not mate up with the early heads. You could find a cheap lower intake pretty easy I would think (tt/na are the same).
Oriznal
22:05:03 04/27/16
Re: 91 tt head mating with 95 na short block
Tech@EPR
23:03:12 04/27/16
the block/head match is not the problem -
shaggee
08:52:45 04/28/16
Re: the block/head match is not the problem
Oriznal
23:17:49 04/28/16
You will have to change over two exhaust studs iirc.
michaell32 (FL)
08:05:40 04/29/16
Re: You will have to change over two exhaust studs iirc.
Oriznal
19:25:13 04/29/16
Heads & lower plenum need to be matched together AND...
06:52:10 04/29/16
