TwinTurbo.NET: Nissan 300ZX forum - Get the drop in conversion, pull the plenum and splice in
Subject Get the drop in conversion, pull the plenum and splice in
Posted by YlwPrlZTT on April 15, 2016 at 5:34 PM
  This message has been viewed 329 times.
In Reply To Injector Failure posted by 91-Z32 on April 15, 2016 at 03:25 PM
Message the new connectors. It should not take you long, but if you've never pulled the plenum before I'm guessing about 2 days to do the entire job with about 4-5 hours each day. Make sure you have all the parts needed (new plenum gasket and everything else you might need). Good luck!
P.S. DO NOT REPLACE WITH OLD STYLE INJECTORS!
