TwinTurbo.NET: Nissan 300ZX forum - Sorry forgot to add, normally a crank rear seal leak doesn't
jzack
on April 14, 2016 at 1:42 PM
Back of the motor at tranny junction could very likely be
posted by jzack
on April 14, 2016 at 12:35 PM
cause smoking. The leak needs to be higher up on the engine but given you just did the repair job there could be some WD40, PB Blaster or oil on the exhaust manifold that needs to burn off a bit.
Valve cover dilemma?
KeepinitClassy
17:58:55 04/12/16
Can you describe the procedure followed for the valve cover
jzack
20:02:09 04/12/16
Re: Can you describe the procedure followed for the valve cover
KeepinitClassy
20:57:24 04/12/16
Re: Re: Can you describe the procedure followed for the valve cover
Cjw3
22:15:28 04/12/16
Much more likely that it's an injector or coil pack issue
01:13:10 04/13/16
The intake gaskets do require a small amount of RTV, where
jzack
09:42:43 04/13/16
^^^I just resealed my valve covers not too long ago and I
YlwPrlZTT
02:15:57 04/14/16
Re: The intake gaskets do require a small amount of RTV, where
KeepinitClassy
04:47:42 04/14/16
jzack
12:35:11 04/14/16
Sorry forgot to add, normally a crank rear seal leak doesn't -
jzack
13:42:40 04/14/16
If you don't see oil dripping
FrozTTy
08:10:23 04/13/16
Re: If you don't see oil dripping
KeepinitClassy
04:49:53 04/14/16
Check the brake master cylinder, too
ChristopherTheOne
23:25:58 04/13/16
Re: Check the brake master cylinder, too
KeepinitClassy
04:52:20 04/14/16
Re: Valve cover dilemma?
wb3ztt
14:25:35 04/14/16
