TwinTurbo.NET: Nissan 300ZX forum - Lifter tick is not the same as rod knock
Subject Lifter tick is not the same as rod knock
Posted by ThisIsSparTTa on April 04, 2016 at 11:53 AM
  This message has been viewed 332 times.
In Reply To Re: Try cranking it over with the spark plugs removed posted by Thetroll865 on April 04, 2016 at 10:40 AM
Message Do you have rod knock? If so, this can make the engine seem seized, and it won't want to crank.
Here's what my rod knock sounded like:
https://www.youtube.com/watch?v=mfw2CW7vqIg
https://www.youtube.com/watch?v=kT8gmlimxJg
Rod knock is going to require a shortblock rebuild, and shouldn't be driven on unless you want to replace the crank too. Lifter tick is mostly just annoying.
Otherwise, could be your battery, could be your starter, or based on your other posts could be a different electrical issue.
