TwinTurbo.NET: Nissan 300ZX forum - Tension rod bushings typically make the steering shake on
Subject Tension rod bushings typically make the steering shake on
Posted by Bernie (NoVA) on April 03, 2016 at 11:06 PM
  This message has been viewed 323 times.
In Reply To Maybe the sway bar or tension rod bushings. posted by michaell32 (FL) on April 02, 2016 at 09:53 PM
Message braking because they allow the wheels to toe in too much.
Failed sway bushings would squeek, end links may click & pop if worn out.
Louder pops are usually older struts or (unlikely in this case) incorrectly installed springs which have been bound up or tensioned.
Bernie Bilski
berniebilski@cox.net
