TwinTurbo.NET: Nissan 300ZX forum - The crankshaft journals can be inspected with a micrometer
Subject The crankshaft journals can be inspected with a micrometer
Posted by -Grimm- on April 03, 2016 at 12:31 AM
  This message has been viewed 261 times.
In Reply To Re: Of course there's a way to measure it posted by FL300zx on April 02, 2016 at 03:49 PM
Message And the bores can be checked with a dial bore gauge.
You can set up a sort of jig to check concentricity of the crank journals and main journals if desired, I don't believe main walk is as much a concern for the VG as it has an integral cap girdle.
When you get it apart you should be able to visually tell whether it's toast or not; if the crank surfaces are still shiny chances are you're good to go. If the spun bearing marred the surface it is done for.
Apparently (below) the check valves are available. Before installing you should inspect the check valve OD and bore ID (gauge pin for that small of a bore) to ensure there is a proper amount of press fit.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2008 Honda Civic (DD)
2014 Nissan Murano (DD)
1969 Chevy C10 (Toy)
1969 Chevelle (Toy)
