TwinTurbo.NET: Nissan 300ZX forum - Re: Need Help with proceedure. I'm dropping my rear suspension
Subject Re: Need Help with proceedure. I'm dropping my rear suspension
Posted by Dallas DamonZ on April 02, 2016 at 3:27 PM
  This message has been viewed 356 times.
In Reply To Need Help with proceedure. I'm dropping my rear suspension posted by ZTicket(Dallas) on April 02, 2016 at 01:54 PM
Message OD:
From memory, I think all you have to do is disconnect the electricals, remove the endlink bolts on each hub and then remove the rack from the subframe... mostly 17mm bolts I believe. Wire up the rack so it's not hanging by the lines. Should have to crack the lines and make a mess.
OR buy the replacement bar and S-can the rack. get an alignment, done.
Later
Click here to e-mail me!Click here for Twin Turbo Zs of Dallas!
When was the last time you *really* did something with your Z to call yourself a Z enthusiast?
Member #1 PETZ
