TwinTurbo.NET: Nissan 300ZX forum - Re: I'm not sure the problems you are having are related to the
Subject Re: I'm not sure the problems you are having are related to the
Posted by aorqo on March 27, 2016 at 11:05 AM
  This message has been viewed 321 times.
In Reply To I'm not sure the problems you are having are related to the posted by Tanley (ATL) on March 27, 2016 at 09:56 AM
Message I put a Comp clutch stage 2 in a NA and it had more pedal feel. At that time I also put in a new slave. MC appeared great, no leaks, worked well for about a year. One day it was a little weird feeling, and I tried to bleed it from the damper\booster and got air. I Looked at the MC and it was leaking. I replaced it and have had no problems. All of the parts can leak internally but generally do not. I would not consider the damper essential, and I have seem it bypassed in other Zcars. I have removed the damper from a 240 and installed a single hard line, it made the clutch feel very good. All the damn thing does is make your pedal feel sissy.
