TwinTurbo.NET: Nissan 300ZX forum - Re: Clutch fork pivot balls: long vs short.
Subject Re: Clutch fork pivot balls: long vs short.
Posted by Rob260 on March 26, 2016 at 6:37 AM
  This message has been viewed 317 times.
In Reply To Clutch fork pivot balls: long vs short. posted by Pearl_TTZ on March 21, 2016 at 06:10 PM
Message You have to match the ball to the fork.
If you're using the 350z fork you need to use the shorter pivot as the fork is solid and sits on top of the ball.
If you're using a factory pressed 300zx fork then you use the longer pivot as the ball sits inside of the fork.
