TwinTurbo.NET: Nissan 300ZX forum - The ECU signal to the PTU is not a ground signal.
Subject The ECU signal to the PTU is not a ground signal.
Posted by DVDBURN (MD) on March 24, 2016 at 9:34 PM
  This message has been viewed 622 times.
In Reply To 300zx electrics can be mind numbing..... posted by zx299 on March 24, 2016 at 07:04 PM
Message The ECU signal to the PTU is a positive voltage. The PTU has its own circuit that grounds the coil packs. This is why the PTU gets hot. It has internal transistors which are an equivalent of MOSFETs. They form a short circuit when switched on via the ECU positive voltage. That short grounds the primary winding of the coil pack. And it's actually the release of the ground signal to the coil pack that causes the spark plug to fire. The voltage in the secondary winding of the coil pack to the spark plug is created via inductance from the primary winding when the electromagnetic field in the primary winding collapses after it is turned off by the release of the ground signal.
www.mytwinturbo.com
Nissan Data Voice on YouTube
