TwinTurbo.NET: Nissan 300ZX forum - It's possible the tube is draining fine for low water
jzack
on March 24, 2016 at 7:54 PM
The tube itself is draining properly, and I don't see any
posted by Goldchocobo
on March 24, 2016 at 07:50 PM
volumes but has enough of a blockage to back-up under higher flow issues. If the tube has a crack - that backup could be the issue driving the leak? Just a guess but worth verifying for sure....
The mystery leak
Goldchocobo
16:14:53 03/24/16
So just to be clear...its both coming from above/rear of the
jzack
17:16:27 03/24/16
Correct.
Goldchocobo
19:45:48 03/24/16
Re: The mystery leak
gbhrps
18:42:49 03/24/16
Re: Re: The mystery leak
gbhrps
18:43:41 03/24/16
I'm not the poster but I agree with your diagnosis...
jzack
19:17:49 03/24/16
Goldchocobo
19:50:23 03/24/16
It's possible the tube is draining fine for low water -
jzack
19:54:00 03/24/16
I will verify and report back. (n/m)
Goldchocobo
20:02:23 03/24/16
Well, I flooded the t top channels with an overwhelming
Goldchocobo
22:16:50 03/24/16
Is the seal on the 1/4 glass disturbed. Check tube on
01:34:35 03/25/16
Thanks Bernie, will do. (n/m)
Goldchocobo
01:41:29 03/25/16
To eliminate drain tube as a possible leak source put a >>>
ZUL8TR
07:00:03 03/25/16
That's precisely what I did, no leak.
Goldchocobo
11:25:59 03/25/16
Fixed it!
Goldchocobo
19:39:30 03/25/16
good for you (n/m)
ZUL8TR
03:10:12 03/26/16
Pix. (n/m)
21:23:21 03/27/16
Re: Pix.
Goldchocobo
13:21:55 03/28/16
