TwinTurbo.NET: Nissan 300ZX forum - I decided to Experiment with the '90 set up
Subject I decided to Experiment with the '90 set up
Posted by Cjw3 on March 23, 2016 at 7:19 AM
  This message has been viewed 245 times.
In Reply To I tossed a '96 NA into a '90 NA Chasis.. posted by Cjw3 on March 22, 2016 at 09:47 PM
Message I already had other Z to drive, so the '90 NA was my toy for a while.. so I could learn..
I did the Ford Truck Motor Mounts.. DO NOT LEAVE THE HOSE CLAMPS AT THE TOP OF THE T-BODY .. it will leave dents on the hood.. Damit.. Gives a little more room on the Side of the Engine.. About 35$ each
I removed the Hot Start Fuel Pressure increase Sol on the Left Intake Mount.. cleans up the Side..
I left all the other Smog Stuff.. I'm in California..
Removed the Clutch Bleader Pipe on the Left Fender well..
Rewired the 'Power Wire' going back into the Fuseable Links to a SINGLE LARGER wire that goes to the battery..
Using Acid Rust Remover, I cleaned and Painted the Battery Tray, and rmoved all the 'Road Trash' that collects under it and the Power Brake Area..
Cj
