TwinTurbo.NET: Nissan 300ZX forum - I tossed a '96 NA into a '90 NA Chasis..
Subject I tossed a '96 NA into a '90 NA Chasis..
Posted by Cjw3 on March 22, 2016 at 9:47 PM
  This message has been viewed 281 times.
In Reply To 96 tt engine in 1990 tt car posted by aorqo on March 22, 2016 at 02:14 PM
Message TPS and Left T-Body are Different.. Change Them..
The Idle air Hard Pipe next to the Left Side of the Intake is Different.. Change it and the Soft Pipe.
Left Intake Support Bracket has an Additional Evap Sol.. use the 90 bracket
Swap over the Intake Cams/Gears/VTC Sols.. They will just drop in.
Injector Plugs are Different.. need to fix it on the Harness..
At this time Remove/Rewire for the PTU Sub Harness Delete..
That was all I had to do to make the '96 run like a '95 Motor
Cj
