TwinTurbo.NET: Nissan 300ZX forum - Rear shock lower bushings are not too bad to replace
Subject Rear shock lower bushings are not too bad to replace
Posted by RomChip200 on March 09, 2016 at 6:41 AM
  This message has been viewed 508 times.
In Reply To My Bushings posted by Cjw3 on March 03, 2016 at 09:21 PM
Message I did them last we, in place, just removing the bottom of the shock of course. No need to remove the Hicas arms
The tool you need is this C clamp/press:
You need to find combination with the tool and sockets to push the inner sleeve and break the rubber, then hacksaw the outer sleeve.
Fitting the ES bushings requires also some imagination with the C press as the poly bushings never go straight when pressed
