TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Fuel Pump seems to not be working.
Subject Re: Re: Re: Fuel Pump seems to not be working.
Posted by mypakZ on March 08, 2016 at 10:19 PM
  This message has been viewed 273 times.
In Reply To Re: Re: Fuel Pump seems to not be working. posted by mypakZ on March 07, 2016 at 11:11 AM
Message Found the controller but have not tested it yet. i found another thread that suggested to apply 12 vdc directly to the pump to see if it works. i did this and the pump turned on. i reconnected the pump and the relay and again when i turn the key nothing. Will the pump burn out with a constant 12vdc applied while driving. So How can i distinguish between the Controller and the ECM (possibly)...it does seem odd for the ECM to ONLY be bad in reference toward the fuel pump. until i start the car i don't know if anything else is not working yet. I searched for trying to make a distinction between the two and it pulls up a huge amount of info to go thru so if you have any insight PLS let me know.
