TwinTurbo.NET: Nissan 300ZX forum - I've had good results using Black Silicone Permatex
Subject I've had good results using Black Silicone Permatex
Posted by ThunderZ on February 18, 2016 at 5:35 PM
  This message has been viewed 300 times.
In Reply To electrical connector cleaning + gluing ripped rubber? posted by burntclutch on February 14, 2016 at 05:24 PM
Message to seal the wiring- lasts many years.
For cleaning the connectors, if you don't use CorrosionX like they say below, I have successfully used a Dremel w/ a dental like tool I got at Harbor Freight that is small enough and shaped like a toothpick w a rough texture. Using the Dremel adapter/extension makes it easy.
Next is a connection cleaner spray, then I put dielectric grease in there.
