TwinTurbo.NET: Nissan 300ZX forum - I doubt if just turning over the engine will show head>>
Subject I doubt if just turning over the engine will show head>>
Posted by ZUL8TR on February 12, 2016 at 4:21 AM
  This message has been viewed 262 times.
In Reply To Technical questions: #1) How can you increase oil pressure posted by bengula on February 11, 2016 at 11:27 AM
Message gasket leaks but it will give you compression numbers, can add some oil to the cylinders thru plug hole to determine if rings or valves. When engine running the combustion pressure is very much greater than non running compression. Plus there is coolant pressure that is also a consideration for head gasket leak check. That can be done with out engine running with water in system. Suggest you also do a leak down test to determine amount of leakage. What seals did you replace?
ZUL8TR in Orlando,FL
