TwinTurbo.NET: Nissan 300ZX forum - Technical questions: #1) How can you increase oil pressure
Subject Technical questions: #1) How can you increase oil pressure
Posted by bengula on February 11, 2016 at 11:27 AM
  This message has been viewed 279 times.
Message with the motor pulled out. I just replaced all my seals and VTC on a N/A motor put it back in and its leaking again. So I pulled the motor again to help visualization and repairs. I and want to compression test the cylinders to check for head gasket leaks, which I will do by putting the tranny on with starter and cranking. However I also want to build oil pressure and don't know if simply cranking will give me enough to identify oil leaks. Is there a may to increase oil pressure without starting the motor?
