TwinTurbo.NET: Nissan 300ZX forum - Just lube it up a bit and install through the access hole
jzack
on February 02, 2016 at 9:00 AM
Air Con Evaporator Condensate Drain Pipe
posted by SWH80
on February 01, 2016 at 09:16 PM
from inside the car. There's nothing else special, other than grommets or spongy foam that seal up engine bay to cabin openings for other pass through points. Is there a specific issue you are having with air drafts into the cabin?
SWH80
21:16:36 02/01/16
Just lube it up a bit and install through the access hole -
jzack
09:00:26 02/02/16
