TwinTurbo.NET: Nissan 300ZX forum - In order...
Subject In order...
Posted by -Grimm- on January 25, 2016 at 10:24 AM
  This message has been viewed 313 times.
In Reply To electrical connectors, washer pump, and startup knocking posted by burntclutch on January 24, 2016 at 08:08 PM
Message As far as your connectors go, I would skip to checking a few key connections. Namely the AAC, FICD, AICV mentioned above, the PTU subharness (the PTU itself has weatherproof connectors that I have never seen corrode), water temp and gauge sensors on the front coolant pipe.
Where were you grounding your DMM? If through the plug, try grounding directly to the chassis. Usually a bad ground shows up like you describe (the DMM displays erratic, low voltage readings when sensing power)
Unless you hear a definite knocking noise (not a miss, but a knock)... It just sounds like the car is having a hard time raising the idle upon initial start.
If you have the time, I would try cleaning the IACV (+FICD) and AAC.
Theyre both on the back of the upper intake plenum, takes 10mm socket to remove. Youll need a new gasket too.
It would be more believable if it were having trouble idling as well, but its worth a shot. If you want to try more of a fast and dirty method, tap them with a wrench or other solid object, I have been able to free up a stuck AAC doing that (then I removed it and cleaned it the proper way)
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2008 Honda Civic (DD)
1969 Chevy C10 (Toy)
1969 Chevelle (Toy)
