TwinTurbo.NET: Nissan 300ZX forum - Re: Temp gauge drops
Subject Re: Temp gauge drops
Posted by Diplomat1 on January 19, 2016 at 6:29 PM
  This message has been viewed 513 times.
In Reply To Temp gauge drops posted by tinner on January 19, 2016 at 04:08 PM
Message It's probably a loose wire at the coolant temp sensor. It's on ur hard water pipes on the front of the motor. Look for the 1 wire sensor and see if it's loose or corroded. Best way to tell if the wire is good is to ground the wire and see if the gauge reads full hot. If it does then ur wire is good and u need to fix the connection or replace sensor
