TwinTurbo.NET: Nissan 300ZX forum - things to check
Subject things to check
Posted by FrozTTy on January 17, 2016 at 7:14 AM
  This message has been viewed 525 times.
In Reply To hesitation posted by plenum on January 17, 2016 at 01:55 AM
Message Fuel filter
Spark plug gap (make sure you are running proper NGK plugs)
O2 sensors (perform heated o2 sensor test)
Corrosion - clean every stinkin connector you can, I'm sure they are all corroded
Check/set your base idle
Check/set tps
Clean throttle bodies
Etc etc there is plenty more that can cause a z to hesitate...
