TwinTurbo.NET: Nissan 300ZX forum - PS: if leaks do not stop mechanical repair required >>>
Subject PS: if leaks do not stop mechanical repair required >>>
Posted by ZUL8TR on January 14, 2016 at 4:40 AM
  This message has been viewed 464 times.
In Reply To Check and clean the solenoid at the PS rack>>>>>>. posted by ZUL8TR on January 14, 2016 at 04:29 AM
Message on the power steering rack and they are bigger than what Lucas can fix. But give the Lucas some time to seal. I used it on the wife's Infiniti it took about a month or so but it sealed it. Leak helped the old boot to fail, replaced the boot after leak stopped. To prevent dirt from getting on the PS piston shaft and causing further damage while waiting for leak to stop I zip tied a plastic baggy wrap over the broken boot with slack to allow PS rack movement- worked great but definitely temp getto.
ZUL8TR in Orlando,FL
