TwinTurbo.NET: Nissan 300ZX forum - Re: TPS problems
Subject Re: TPS problems
Posted by Rob260 on January 10, 2016 at 1:06 AM
  This message has been viewed 599 times.
In Reply To TPS problems posted by Rob260 on January 09, 2016 at 11:47 PM
Message Have checked that the throttle bodies are in the "closed" position -they are and they are sealed tight.
I've found that if I remove the TPS and rotate the plastic gear with a screwdriver I can get it to a position that outputs .5v, however this is about 180* out from where it needs to be to fit onto the throttle body cam. I've checked the position of the cam against that on a known working motor and they are the same.
