TwinTurbo.NET: Nissan 300ZX forum - Re: T-belt installed and really off the timing marks could cause
Subject Re: T-belt installed and really off the timing marks could cause
Posted by Diplomat1 on January 07, 2016 at 9:03 AM
  This message has been viewed 535 times.
In Reply To T-belt installed and really off the timing marks could cause posted by jzack on January 07, 2016 at 08:47 AM
Message Jzack thanks for the response. Even if the timing is off wouldn't that give bad compression numbers? He relocated the ptu to the glovebox area and I am gonna check that and then do the test for the cas to hear all fuel injectors click when turning the cas. I will take off the driver side timing cover also. I am praying he didn't damage the head or block and now the compression is gone. Will get back with some results thanks
