TwinTurbo.NET: Nissan 300ZX forum - Re: All these videos show is that resetting leans the engine out
Subject Re: All these videos show is that resetting leans the engine out
Posted by Metacom on January 05, 2016 at 4:32 PM
  This message has been viewed 681 times.
In Reply To All these videos show is that resetting leans the engine out posted by OverZealous (CT) on January 04, 2016 at 06:12 PM
Message Here's a capture of Conzult, engine at 2k:
[ http://1drv.ms/1UuIbn7 ]
I did a compression test today as well:
Cyl 1: 210
Cyl 2: 200
Cyl 3: 200
Cyl 4: 200
Cyl 5: 210
Cyl 6: 200
I also dialed the TPS down to .44 since, couldn't set it on .45 oddly.
Used the TPS adjust/idle adjust screen in Conzult and set the idle RPM into the green sector although this put the idle 100 RPM higher than spec, it results in a smoother idle, the miss is very small sometimes doesn't happen.
But the ignition timing likes to jitter between 5-6 deg BTDC. Dial the RPM back down to FSM 750 and it goes back to 10 BTDC but the rough idle and noticeably miss returns...
