TwinTurbo.NET: Nissan 300ZX forum - Video captures of Conzult after resetting self learn
Subject Video captures of Conzult after resetting self learn
Posted by Metacom on January 04, 2016 at 4:48 PM
  This message has been viewed 900 times.
Message Got a 96NA. Been having a rough idle, small miss some where.
Today I was using Conzult and decided to try the reset self learn function, it caused the idle to smooth out a lot.
After driving it goes back to a rough idle / small miss.
Conzult capture after driving:
[ http://1drv.ms/1SvKbgo ]
And here it is right after pressing the reset self learn:
[ http://1drv.ms/1kGxFwS ]
Vacuum lines all good, also used a boost leak tester
Injectors OHM OK
Can hear each injector clearly
Coil Packs OHM OK
TPS OK (re tightened it after it appears to be jumping around a bit)
O2's cycle between rich and lean at 2k RPM
No MIL/Codes
IACV tests ok
CAS OK
Idle speed adjusts easily to FSM 750 +/-50RPM
Ignition timing set to 10 deg BTDC warmed up
All connectors are spotless
PTU tests OK
Power balance test via Conzult stalls the car on the first cylinder, however unplugging the coil packs manually results in an RPM drop for each cylinder.
Disconnecting the TPS sensor results in smooth, miss free idle, that is at 800+RPM. When dialed down to 650 +/-50RPM the idle starts hunting. Ignition timing stays at 10 Degs.
TPS plugged in at 800+ RPM it is smoother but there is still miss.
Its all limited to idle, driveability is fine and the engine is responsive, revs past 4k no problems.
